[osgeo4w-dev] [osgeo4w] #473: create a geos-c++ package
trac_osgeo4w at osgeo.org
Mon Jan 11 08:53:46 PST 2016
Reporter: rashadkm | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: |
Comment (by jef):
Replying to [comment:6 rashadkm]:
> Let us imagine that we port ossim geos c++ part to c api. And there
comes otb that uses ossim. so the problem comes back when ossim is
compiled with a different compiler and and otb or something is using a new
one.
Sure. ossim should be built with the same compiler as otb - if it want's
to be available for otb (w/o providing a C-API). And AFAIK otb is already
using Qt (which also doesn't provide a C API) - so everything there is
already tied to msvc2010 (which is what Qt was built with).
> Is it possible to isolate these stuff in seperate directories in the
server.
> msvc2010/{x86,x64}/ossim,geos,otb,qt,
> msvc2013/{x86,x64}/ossim,geos,otb,qt
Um, who's going to produce all those packages?
> Users can choose between different osgeo4W installers depending on the
version of compiler.
Users probably don't care about the compiler versions.
> This also allows to chime in mingw toolchain. So there is no need to mix
msvc and mingw dll as in the case of grass.
> If msvc2013 or 2015 have not much packages... then that is not a
problem. It will arrive later.
Sorry I don't follow.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/473#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
