[osgeo4w-dev] [osgeo4w] #538: gdal_array.OpenNumPyArray() fail
OSGeo4W trac_osgeo4w at osgeo.org
Tue Aug 1 09:17:26 PDT 2017
Reporter:  jakimowb  |      Owner:  osgeo4w-dev@…
    Type:  defect    |     Status:  new
Priority:  major     |  Component:  Package
 Version:            |   Keywords:  gdal_array
 The following python lines cause a crash of the entire python instance on
 Windows Server 2012 R2 (64 bit) and Windows 8.1 Pro (64 bit):
 import numpy
 from osgeo import gdal_array
 a = numpy.ones((10,20))
 gdal_array.OpenNumPyArray(a)
 {{{gdal_array.OpenNumPyArray}}} is used in the handsome
 {{{gdal_array.SaveArray(src_array, filename, format = "GTiff", prototype =
 None)}}} routine. If, for example, called on a QGIS Python console, the
 entire QGIS instance crashes.
 GDAL: 2.2.1, released 2017/06/23 gdal202.dll
 numpy: 1.12.1
 python: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/538>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
