[osgeo4w-dev] [osgeo4w] #474: Outdated CA Certificates
trac_osgeo4w at osgeo.org
Tue Aug 8 08:46:20 PDT 2017
Reporter: maphew | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: curl, openssl |
Comment (by rzoller):
It seems that there are still issues with this, since the issue mentioned
here with pip was only a symptom of outdated CA certificates, and it looks
like the certificates haven't actually been updated.
As suggested in [[http://osgeo-org.1560.x6.nabble.com/gdal-dev-libcurl-
and-the-certificates-and-Windows-tp5322919p5323113.html|this recent gdal-
dev thread]], probably the best solution would be to build libcurl with
SChannel support instead of OpenSSL.
Btw, is osgeo4w still being actively developed? The only
[[https://trac.osgeo.org/osgeo4w/browser|source code I found]] has its
last commit 17 months ago...
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/474#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
