[osgeo4w-dev] QT Designer is missing?
Jürgen E. Fischer
jef at norbit.de
Thu Jun 1 23:55:18 PDT 2017
Hi Casper,
On Fri, 02. Jun 2017 at 06:14:38 +0000, Casper Børgesen wrote:
> I have installed the ones marked with '*' and the remaining 'full' seems to
> be older versions of the others, so normally I wouldn't look at them for
> missing items.
The "full" packages just have dependencies and don't have any files. So
there's no need to update their version numbers.
> Since I haven't installed any 'full' versions and the QT designer only is
> available through them, why do I get Designer batch files for each of the
> installations I have made?
qt4-devel dependency moved from the full to the qgis packages.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20170602/7c8d0700/attachment.sig>
More information about the osgeo4w-dev
