[osgeo4w-dev] QT Designer is missing?
Casper Børgesen
caboe at sdfe.dk
Thu Jun 1 23:14:38 PDT 2017
Hi Jürgen
If I look at the various available qgis installs in OSGeo, I get the following:
*2.18.9-1 - qgis
*2.99.0-91 - qgis-dev
2.14.0-1 - qgis-full
2.99.0-1 - qgis-full-dev
2.18.0-1 - qgis-full-rel-dev
*2.14.15-1 - qgis-ltr
2.8.2-1 - qgis-ltr-full
I have installed the ones marked with '*' and the remaining 'full' seems to be older versions of the others, so normally I wouldn't look at them for missing items.
Since I haven't installed any 'full' versions and the QT designer only is available through them, why do I get Designer batch files for each of the installations I have made?
Regards, Casper
From: osgeo4w-dev [mailto:osgeo4w-dev-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 1. juni 2017 18:08
To: osgeo4w-dev at lists.osgeo.org
Subject: Re: [osgeo4w-dev] QT Designer is missing?
Hi Casper,
On Thu, 01. Jun 2017 at 13:55:51 +0000, Casper Børgesen wrote:
> I just tried to run the QT designer installed with OSGeo4W (x64) and I just
> get an error message that the Designer.exe cannot be found (and indeed it
> isn't located within the 'bin' folder in the OSGeo folder.
You probably installed qgis and not qgis-full. qgis doesn't depend on
qt4-devel, which has designer. qgis-full however does.
Same for qgis-ltr and qgis-ltr-full.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
More information about the osgeo4w-dev
