[osgeo4w-dev] QT Designer is missing?
Jürgen E. Fischer jef at norbit.de
Thu Jun 1 09:08:06 PDT 2017
Hi Casper,
On Thu, 01. Jun 2017 at 13:55:51 +0000, Casper Børgesen wrote:
> I just tried to run the QT designer installed with OSGeo4W (x64) and I just
> get an error message that the Designer.exe cannot be found (and indeed it
> isn't located within the 'bin' folder in the OSGeo folder.
You probably installed qgis and not qgis-full.  qgis doesn't depend on
qt4-devel, which has designer.  qgis-full however does.
Same for qgis-ltr and qgis-ltr-full.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20170601/d8c08f89/attachment.sig>
More information about the osgeo4w-dev mailing list
