[osgeo4w-dev] null grid missing from PROJ 5 package
Jürgen E. Fischer jef at norbit.de
Wed Apr 18 01:44:40 PDT 2018
Hi Kristian,
On Wed, 18. Apr 2018 at 08:31:59 +0000, Kristian Evers wrote:
> It is not clear to me why that has changed. I guess the intention is that
> everything in share/proj is included in the archive. I can't see from the
> build script how share/proj is populated though, so something may have gone
> wrong in that step. Maybe you can clear that up, Jürgen?
package.cmd runs install-all from makefile.vc with INSTDIR set to the current
directory, which runs install-all from nad/makefile.vc, which copies the file
to PROJ_LIB_DIR, which is $(INSTDIR)\SHARE.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20180418/fa2cd205/attachment.sig>
More information about the osgeo4w-dev mailing list
