[osgeo4w-dev] QGIS3: packages & versioning
Jürgen E. Fischer
jef at norbit.de
Wed Feb 28 13:27:30 PST 2018
Hi Tobias,
On Wed, 28. Feb 2018 at 22:11:56 +0100, Tobias Wendorff wrote:
> the expert installer of OSGeo4W has become a little bit confusing
> over all the QGIS3 versions [see below].
> Right now, "qgis-rel-dev" is 3.0-1, while "qgis" is 3.0.0-4.
> Shouldn't the daily nightlies have a higher version?
No. The last part is just the package version - ie. number of the build on
that version. It just has to increase - for gdal-dev it's for example the
svn revision.
> Also "qgis-full" is 3.0-1... Isn't this just the meta package
> for stable qgis, which is 3.0.0.-4 in a single install?
qgis + otherwise optional dependencies eg. for plugin (and everything that's to
be included in the standalone).
> Wouldn't it be logical to move all the dev & deps into a "dev" category?
The pdb and deps should probably not be in the desktop category. Fixed.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20180228/dc53510b/attachment.sig>
More information about the osgeo4w-dev
