[osgeo4w-dev] [osgeo4w] #574: gdalbuildvrt fails handling wildcards under Win10 1803
trac_osgeo4w at osgeo.org
Sat Jul 14 09:12:59 PDT 2018
Reporter: Langlaeufer | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: GDAL, |
Comment (by hellik):
Replying to [comment:2 deezx]:
> I have the same issue with gdalbuildvrt using Win10 (1803)
> On my machine building the VRT **fails only for the first file of the
folder in wildcard matching**, other files in same folder are added to the
VRT. So if I have four tiles in a foulder, the first file produces an
error, but the other tree files are added. The first file fails, because
the first filename matching the wildcard is **truncated to a single
char**, e.g. if the file is **folder/abc.tif** the wildcard
**folder/*.tif** produces the following error:
> ERROR 4: folder\a: No such file or directory
> Warning 1: Can't open folder\a. Skipping it
> Issue affects all current Windows versions of QGIS (2.18.21, 3.2.0)
using GDAL 2.2.4 from OSGEO4W build, in Windows 10 (1803), 64bit.
> see:
> https://github.com/OSGeo/gdal/issues/568
> https://issues.qgis.org/issues/19192
according to this [https://lists.osgeo.org/pipermail/gdal-
dev/2011-February/027941.html mail]
SETARGV = $(VCDIR)\lib\setargv.obj
has to be activated in nmake.opt.
looking the
[https://download.osgeo.org/osgeo4w/x86_64/release/gdal/gdal-2.2.4-1-src.tar.bz2
GDAL's OSGeo4W receipe]
''nmake64.opt'':
SETARGV = "$(VCDIR)\lib\amd64\setargv.obj"
is activated OSGeo4W's GDAL.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/574#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
