[osgeo4w-dev] environb import error in python 3.6.0 under osgeo4w
Jürgen E. Fischer jef at norbit.de
Wed Jun 20 07:11:38 PDT 2018
Hi Olivier,
On Wed, 20. Jun 2018 at 14:52:15 +0200, Olivier P. Francois wrote:
> I have python 3.6.0-2 installed on my computer through the osgeo4w64
> installer in windows 10.
GRASS in OSGeo4W currently only uses python2 - so that error doesn't normally
appear.
And os.environb is not supported on windows
(see https://docs.python.org/3.6/library/os.html#os.environb)
So this apparently is an upstream GRASS bug - but as far as I can tell python3
support in GRASS is work in progress (see
https://trac.osgeo.org/grass/ticket/3565).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20180620/ce7741a0/attachment.sig>
More information about the osgeo4w-dev mailing list
