[osgeo4w-dev] proj 5 update?
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Sun Mar 25 08:44:00 PDT 2018
Hi Kristian,
Am So, 25.03.2018, 17:39 schrieb Kristian Evers:
> The bug you are referring to is not fixed in PROJ 5.0.0 so an
> update will not really help you in that regard.
I thought you've commited a patch for this some weeks ago?
In OSGeo4W, there's some 5.0.0-RC available only (not the
final one).
> Best option for that is to use 4.9.3.
It's not possible: QGIS3 doesn't start with proj4. You'll get an
error on proj.dll when switching back to proj4.
> A bug fix release is on its way though, so when that is out it
> should be safe to update the OSGeo4W PROJ package and have it
> as the default.
Oh, I thought it's in GIT already.
Okay, need to stay on QGIS2 then for normal use
Thanks for the information :)
Tobias
> There?s already a ticket for this:
> https://trac.osgeo.org/osgeo4w/ticket/558
> The bug you are referring to is not fixed in PROJ 5.0.0 so an update will
> not really help you in that regard. Best option for that is to use 4.9.3.
> A
> bug fix release is on its way though, so when that is out it should be
> safe
> to update the OSGeo4W PROJ package and have it as the default.
> /Kristian
> On 25 Mar 2018, at 14:31, Tobias Wendorff
> <tobias.wendorff at tu-dortmund.de<mailto:tobias.wendorff at tu-dortmund.de>>
> wrote:
> Hi there,
> could anyone please update proj v5 package in OSGeo4w?
> Right now, it's 5.0.0RC4-1, which (on my system) still has massive
> problems with EPSG:3857. It is not possible to use proj4 anymore
> (QGIS3 crashes on startup with an error message).
> Since there's a patch for this bug, it would be nice to have this
> in OSGeo4w for testing and normal use.
> Best regards,
> Tobias
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org<mailto:osgeo4w-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
