[osgeo4w-dev] proj 5 update?
Helmut Kudrnovsky
hellik at web.de
Sun Mar 25 12:15:09 PDT 2018
Kristian Evers-2 wrote
> There’s already a ticket for this:
> https://trac.osgeo.org/osgeo4w/ticket/558
> The bug you are referring to is not fixed in PROJ 5.0.0 so an update will
> not really help you in that regard. Best option for that is to use 4.9.3.
> A
> bug fix release is on its way though, so when that is out it should be
> safe
> to update the OSGeo4W PROJ package and have it as the default.
> /Kristian
for the record, GRASS trunk is PROJ 5 ready:
https://lists.osgeo.org/pipermail/grass-user/2018-March/078023.html
https://lists.osgeo.org/pipermail/grass-commit/2018-March/043391.html
to
https://lists.osgeo.org/pipermail/grass-commit/2018-March/043408.html
libproj: +new GRASS API for coordinate transformation
this isn't backported to the 7.4.-release branch, not sure it will ever be.
so it could be that GRASS 7.4.-release branch has to live with 4.9.3 for a
while.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/osgeo4w-dev-OSGeo-Win32-Installer-List-f3765018.html
More information about the osgeo4w-dev
