[osgeo4w-dev] PROJ4 and PROJ5 updates
Howard Butler
howard at hobu.co
Fri Oct 19 12:27:21 PDT 2018
Jürgen (presumably),
Can you relay the status of PROJ packages for OSGeo464? I think we have
an issue where GDAL is now pointed at the new PROJ5 packages, but there
is a bug in how PROJSO is resolved. If I set the PROJSO environment
variable to proj_5_2.dll or proj.dll, my PDAL application that utilizes
PROJ through GDAL works correctly. Setting this was not necessary before
the PROJ update(s).
Should we add the PROJSO=proj_5_2.dll environment setting to the
startup? I suppose that will break things that use old GDAL/PROJ setups.
Alternatively, maybe LIBNAME [1] needs to be set to something different
to match the PROJ DLL and PROJ version?
I'm unsure how to move forward...
Howard
[1]
https://github.com/OSGeo/gdal/blob/d5f6bb89b0e0db0a06489419050d432e8f58ff47/gdal/ogr/ogrct.cpp#L113
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20181019/108f1680/attachment.sig>
More information about the osgeo4w-dev
