[osgeo4w-dev]  QGIS fails to install
    Müller, Andreas, Dr. phil.
    muellea at uni-trier.de
    Mon Oct 29 03:04:50 PDT 2018
Dear Jürgen,
Thank you very much!
Dr. Andreas Müller -_- Universität Trier - FB VI - Kartographie, muellea at uni-trier.de
54286 Trier, Behringstr. 29, F 191, ++496512014576
________________________________________
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> im Auftrag von Jürgen E. Fischer <jef at norbit.de>
Gesendet: Sonntag, 28. Oktober 2018 16:16
An: osgeo4w-dev at lists.osgeo.org
Betreff: Re: [osgeo4w-dev] QGIS fails to install
Hi Andreas,
On Tue, 16. Oct 2018 at 12:49:59 +0000, Müller, Andreas, Dr. phil. wrote:
> I confirm that installation works fine, thank you very much!
> But, unfortunately, i detect some errors/differences in Qt5/PyQt5:
> - in Python36 there was an copy of %osgeo4w_root%\bin\qt.conf in apps\Qt5\bin
>   and in apps\python36, now that in Qt5\bin it is missing (not knowing if it
>   is needed by anything)
> - in Qt5/Python36 we had QtWebEngine and QtWebKit, now QtWebEngine is
>   missing. (QGIS-Plugins using it, will not work)
Should all be back again.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
More information about the osgeo4w-dev
