[osgeo4w-dev] QGIS fails to install
    Jürgen E. Fischer
    jef at norbit.de
    Sun Oct 28 08:16:38 PDT 2018
Hi Andreas,
On Tue, 16. Oct 2018 at 12:49:59 +0000, Müller, Andreas, Dr. phil. wrote:
> I confirm that installation works fine, thank you very much!
> But, unfortunately, i detect some errors/differences in Qt5/PyQt5:
> - in Python36 there was an copy of %osgeo4w_root%\bin\qt.conf in apps\Qt5\bin
>   and in apps\python36, now that in Qt5\bin it is missing (not knowing if it
>   is needed by anything)
> - in Qt5/Python36 we had QtWebEngine and QtWebKit, now QtWebEngine is
>   missing. (QGIS-Plugins using it, will not work)
Should all be back again.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20181028/14889ab4/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20181028/14889ab4/attachment.ksh>
More information about the osgeo4w-dev
