[osgeo4w-dev] Wrong GDAL VersionInfo
Pedro Venâncio
pedrongvenancio at gmail.com
Fri May 8 06:48:10 PDT 2020
Hi Jurgen,
You're right, running qgis-rel-dev-g7.bat --postinstall after the change
I've made, fixed the PATH and PYTHONPATH in the .env, and solved the issue!
About the package python3-gdal-dev, do you think it should be installed by
default?
Thank you very much!
Best regards,
Pedro
Jürgen E. Fischer <jef at norbit.de> escreveu no dia sexta, 8/05/2020 à(s)
06:46:
> Hi Pedro,
> On Fri, 08. May 2020 at 00:30:01 +0100, Pedro Venâncio wrote:
> > I tried to change in qgis-rel-dev-g7.bat
> > from
> > call gdal-dev-env.bat
> > to
> > call gdal-dev-py3-env.bat
> > but without success. It seems that something more needs to be changed.
> Any
> > hint?
> Calling qgis-rel-dev-g7.bat once with --postinstall might have worked after
> above change as well (to rewrite the .env).
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200508/d459b965/attachment.html>
More information about the osgeo4w-dev
