[osgeo4w-dev] OSGeo4W Install from Local Directory
Jürgen E. Fischer
jef at norbit.de
Sun Apr 24 07:09:03 PDT 2022
Hi Yannick,
On Sat, 23. Apr 2022 at 18:46:00 +0200, Yannick Portier wrote:
> I'm having a problem when trying to install a former version of QGIS (I
> need Python 3.7 as I'm working on a Win7 PC) where QGIS won't load
> correctly after installation. It's complaining that `icuuc56.dll` is
> missing or that qgis-bin.exe is not a valid Win32 application although I'm
> positive I am using a 64 bits PC.
Your package set is incomplete. But why are you doing that manually to start with?
curl -O http://download.osgeo.org/osgeo4w/v1/osgeo4w-setup-x86_64-v1.exe
osgeo4w-setup-x86_64-v1 -s http://download.osgeo.org/osgeo4w/v1 -O -k -q -P qgis
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220424/2b936a69/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220424/2b936a69/attachment.ksh>
More information about the osgeo4w-dev
