[osgeo4w-dev] OSGeo4W Install from Local Directory
Yannick Portier
yportiercgg at gmail.com
Sun Apr 24 07:27:52 PDT 2022
Hi Jurgen,
Yes, I realized that... I did try to use the Install from Internet option
as usual but I kept having an error saying setup.ini can't be downloaded so
I was stuck there.
By completing the list of requirements, I was able to install QGIS
successfully, so now everything is OK.
Out of curiosity, what is your command doing exactly ? I tried it and it
took a few seconds to process and completed without a problem, but I can't
seem to find anything it may have done.
Many thanks,
Yannick
On Sun, Apr 24, 2022 at 4:09 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Yannick,
> On Sat, 23. Apr 2022 at 18:46:00 +0200, Yannick Portier wrote:
> > I'm having a problem when trying to install a former version of QGIS (I
> > need Python 3.7 as I'm working on a Win7 PC) where QGIS won't load
> > correctly after installation. It's complaining that `icuuc56.dll` is
> > missing or that qgis-bin.exe is not a valid Win32 application although
> I'm
> > positive I am using a 64 bits PC.
> Your package set is incomplete. But why are you doing that manually to
> start with?
> curl -O http://download.osgeo.org/osgeo4w/v1/osgeo4w-setup-x86_64-v1.exe
> osgeo4w-setup-x86_64-v1 -s http://download.osgeo.org/osgeo4w/v1 -O -k -q
> -P qgis
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220424/ccb22745/attachment.html>
More information about the osgeo4w-dev
