[osgeo4w-dev] OSGeo4W Install from Local Directory
Jürgen E. Fischer jef at norbit.de
Fri Apr 29 05:28:32 PDT 2022
Hi Yannick,
On Sun, 24. Apr 2022 at 16:27:52 +0200, Yannick Portier wrote:
> Out of curiosity, what is your command doing exactly ? I tried it and it
> took a few seconds to process and completed without a problem, but I can't
> seem to find anything it may have done.
> > curl -O http://download.osgeo.org/osgeo4w/v1/osgeo4w-setup-x86_64-v1.exe
> > osgeo4w-setup-x86_64-v1 -s http://download.osgeo.org/osgeo4w/v1 -O -k -q -P qgis
Downloads the old installer and runs it:
-s http://download.osgeo.org/osgeo4w/v1   tells it to install from where the old repo reside now (originally was one level up w/o v1),
-O 					  to only use that repo,
-k					  to silently accepts the license agreements,
-q 					  to let it run unattentend and
-P qgis					  to install qgis (and deps).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220429/b712bced/attachment.sig>
More information about the osgeo4w-dev mailing list
