[osgeo4w-dev] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 01:26:02 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by jef):
 `qgis*.vars` doesn't include `SSL_CERT_FILE`, hence it's not included in
 the `.env` and in turn not set, when you start the `.exe` directly (eg. by
 using the shortcut).  In the shell and QGIS from  `qgis*.bat` it should
 work.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:13>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
