[osgeo4w-dev] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
trac_osgeo4w at osgeo.org
Thu May 5 01:45:57 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: |
Comment (by hellik):
Replying to [comment:13 jef]:
> QGIS from `qgis*.bat` it should work.
started here `qgis.bat` in OSGeo4W Ver 2:
# Python Console
# Use iface to access QGIS API interface or type help(iface) for more info
# Security warning: typing commands from an untrusted source can harm your
computer
exec(Path('C:/Users/hkmyr/AppData/Local/Temp/tmpxzb_61_i.py').read_text())
ssl prgcloud.com: FAIL A failure in the SSL library occurred (_ssl.c:1129)
urllib prgcloud.com: FAIL <urlopen error A failure in the SSL library
occurred (_ssl.c:1129)>
ssl www.prgcloud.com: FAIL A failure in the SSL library occurred
(_ssl.c:1129)
urllib www.prgcloud.com: FAIL <urlopen error A failure in the SSL library
ssl www.python.org: OK
urllib www.python.org: OK
ssl grass.osgeo.org: FAIL A failure in the SSL library occurred
(_ssl.c:1129)
urllib grass.osgeo.org: FAIL <urlopen error A failure in the SSL library
ssl www.osgeo.org: FAIL A failure in the SSL library occurred
(_ssl.c:1129)
urllib www.osgeo.org: FAIL <urlopen error A failure in the SSL library
still a failure.
system info
QGIS version
3.24.2-Tisler
QGIS code revision
13c1a028
Compiled against Qt
5.15.2
Running against Qt
5.15.3
Python version
3.9.5
Compiled against GDAL/OGR
3.4.2
Running against GDAL/OGR
3.4.3
PROJ version
9.0.0
EPSG Registry database version
v10.054 (2022-02-13)
GEOS version
3.10.2-CAPI-1.16.0
SQLite version
3.38.1
PDAL version
2.3.0
PostgreSQL client version
unknown
SpatiaLite version
5.0.1
QWT version
6.1.3
QScintilla2 version
2.11.5
OS version
Windows 10 Version 2009
Active Python plugins
kmltools
3.1.10
latlontools
3.5.3
LocatePoints
0.3.4
MultiDistanceBuffer
3.2.4
openlayers_plugin
2.0.0
OSMDownloader
1.0.3
qgisgbifapi
0.3.2
QuickOSM
1.16.0
quick_map_services
0.19.11.1
scriptrunner3
3.0.5
SentinelHub
2.0.0
vrtbuilderplugin
0.9.20210222T174536.master
db_manager
0.1.20
grassprovider
2.12.99
MetaSearch
0.3.6
processing
2.12.99
sagaprovider
2.12.99
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:14>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
