[osgeo4w-dev] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 01:57:23 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by hellik):
 Replying to [comment:14 hellik]:
 > Replying to [comment:13 jef]:
 > > QGIS from  `qgis*.bat` it should work.
 > started here `qgis.bat` in OSGeo4W Ver 2:
 > # Python Console
 > # Use iface to access QGIS API interface or type help(iface) for more
 info
 > # Security warning: typing commands from an untrusted source can harm
 your computer
 exec(Path('C:/Users/hkmyr/AppData/Local/Temp/tmpxzb_61_i.py').read_text())
 > ssl prgcloud.com: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 > urllib prgcloud.com: FAIL <urlopen error A failure in the SSL library
 occurred (_ssl.c:1129)>
 > ssl www.prgcloud.com: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 > urllib www.prgcloud.com: FAIL <urlopen error A failure in the SSL
 library occurred (_ssl.c:1129)>
 > ssl www.python.org: OK
 > urllib www.python.org: OK
 > ssl grass.osgeo.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 > urllib grass.osgeo.org: FAIL <urlopen error A failure in the SSL library
 > ssl www.osgeo.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 > urllib www.osgeo.org: FAIL <urlopen error A failure in the SSL library
 > still a failure.
 > system info
 > QGIS version
 > 3.24.2-Tisler
 > QGIS code revision
 > 13c1a028
 > Compiled against Qt
 > 5.15.2
 > Running against Qt
 > 5.15.3
 > Python version
 > 3.9.5
 > Compiled against GDAL/OGR
 > 3.4.2
 > Running against GDAL/OGR
 > 3.4.3
 > PROJ version
 > 9.0.0
 > EPSG Registry database version
 > v10.054 (2022-02-13)
 > GEOS version
 > 3.10.2-CAPI-1.16.0
 > SQLite version
 > 3.38.1
 > PDAL version
 > 2.3.0
 > PostgreSQL client version
 > unknown
 > SpatiaLite version
 > 5.0.1
 > QWT version
 > 6.1.3
 > QScintilla2 version
 > 2.11.5
 > OS version
 > Windows 10 Version 2009
 > Active Python plugins
 > kmltools
 > 3.1.10
 > latlontools
 > 3.5.3
 > LocatePoints
 > 0.3.4
 > MultiDistanceBuffer
 > 3.2.4
 > openlayers_plugin
 > 2.0.0
 > OSMDownloader
 > 1.0.3
 > qgisgbifapi
 > 0.3.2
 > QuickOSM
 > 1.16.0
 > quick_map_services
 > 0.19.11.1
 > scriptrunner3
 > 3.0.5
 > SentinelHub
 > 2.0.0
 > vrtbuilderplugin
 > 0.9.20210222T174536.master
 > db_manager
 > 0.1.20
 > grassprovider
 > 2.12.99
 > MetaSearch
 > 0.3.6
 > processing
 > 2.12.99
 > sagaprovider
 > 2.12.99
 looking at https://trac.osgeo.org/osgeo4w/ticket/696#comment:2
 import os
 os.getenv("SSL_CERT_FILE")
 os.getenv("SSL_CERT_DIR")
 cert_filet = os.getenv("SSL_CERT_FILE")
 cert_dirt = os.getenv("SSL_CERT_DIR")
 print(cert_filet)
 print(cert_dirt)
 results in
 # Python Console
 # Use iface to access QGIS API interface or type help(iface) for more info
 # Security warning: typing commands from an untrusted source can harm your
 computer
 exec(Path('C:/Users/hkmyr/AppData/Local/Temp/tmpkhsda6a5.py').read_text())
 C:\OSGeo4W\bin\curl-ca-bundle.crt
 C:\OSGeo4W\apps\openssl\certs
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:15>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
