[osgeo4w-dev] 32 or 64 bit library
Paul Burns paulburns at simplexity.com.au
Mon Sep 5 17:27:57 PDT 2022
Hi
I am attempting to build QGIS for windows and have been using a QtCreator 64
bit compiler.
Section 4.1.2 Other tool.. of
https://github.com/qgis/QGIS/blob/master/INSTALL.md
Has a link to 64 bit OSGeo4w, but it returns a 404 Not found.
I note on https://trac.osgeo.org/osgeo4w/ the OSGeo4W network installer,
does not specify if it is 32 or 64 bit?
Are the packages I have downloaded using the OSGeo4W network installer 32
bit, and therefore I will need to compile QGIS as 32 bit?
Thanks for your help.
Paul
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220906/fcb86a6a/attachment.htm>
More information about the osgeo4w-dev mailing list
