[osgeo4w-dev] 32 or 64 bit library
Jürgen E. Fischer
jef at norbit.de
Tue Sep 6 02:41:46 PDT 2022
Hi Paul,
On Tue, 06. Sep 2022 at 09:57:57 +0930, Paul Burns wrote:
> Section 4.1.2 Other tool.. of
> https://github.com/qgis/QGIS/blob/master/INSTALL.md
> Has a link to 64 bit OSGeo4w, but it returns a 404 Not found.
That's outdated. The current recipes for the qgis packages are at:
https://github.com/jef-n/OSGeo4W/tree/master/src/qgis-ltr/osgeo4w/package.sh
https://github.com/jef-n/OSGeo4W/tree/master/src/qgis/osgeo4w/package.sh
https://github.com/jef-n/OSGeo4W/tree/master/src/qgis-dev/osgeo4w/package.sh
https://github.com/jef-n/OSGeo4W/tree/master/src/qgis-ltr-dev/osgeo4w/package.sh
https://github.com/jef-n/OSGeo4W/tree/master/src/qgis-rel-dev/osgeo4w/package.sh
Running package.sh will setup a separate osgeo4w environment with the
dependencies from osgeo4w and build the package.
There's also a workflow on
https://github.com/jef-n/o4w-playground/blob/master/.github/workflows/build-packages.yml
which can produces packages.
> I note on https://trac.osgeo.org/osgeo4w/ the OSGeo4W network installer,
> does not specify if it is 32 or 64 bit?
Not anymore - because OSGeo4W is 64bit only now.
> Are the packages I have downloaded using the OSGeo4W network installer 32
> bit, and therefore I will need to compile QGIS as 32 bit?
Which is far behind to0. OSGeo4W v1 is no longer maintained.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220906/6d99d445/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20220906/6d99d445/attachment.ksh>
More information about the osgeo4w-dev
