[osgeo4w-dev] [osgeo4w] #861: OSGeo4W Setup fails to completely uninstall python3-pyarrow 0.0.0-1
trac_osgeo4w at osgeo.org
Sat Dec 7 03:34:32 PST 2024
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Description changed by andreaerdna:
Old description:
> After uninstalling python3-pyarrow 0.0.0-1 using OSGeo4W Setup, the
> {{{pyarrow}}} folder, containing a is still present in
> {{{apps\Python312\Lib\site-packages\}}}
> This prevents the user to workaround #860 in order to make geopandas and
> pandas correctly work.
New description:
{{{pyarrow}}} folder is still present in {{{apps\Python312\Lib\site-
packages\}}}.
This prevents the user to workaround the side effects of #860 in order to
make geopandas and pandas correctly work.
Removing the {{{pyarrow}}} folder in {{{apps\Python312\Lib\site-
packages\}}} is needed in order to workaround the side effects of #860 and
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/861#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
