[osgeo4w-dev] [osgeo4w] #830: Unattended installation error
trac_osgeo4w at osgeo.org
Wed May 1 00:16:11 PDT 2024
Reporter: gpsaliola | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Description changed by gpsaliola:
Old description:
> Hello,
> I've a problem with `osgeo4w-setup.exe` evergreen installation since few
> days ago.
> I've installed with this command:
> osgeo4w-setup.exe -q -A -a x86_64 -k -L -d -n -N -D -s
> https://download.osgeo.org/osgeo4w/v2 -C Commandline_Utilities -x shell
> -P gpsbabel-gui -P gdal -P proj
> I obtain this when I use gdal_translate.exe utility.
> "missing lz4.dll".
> After I've installed with this command:
> -P gpsbabel-gui -P gdal -P lz4 -P proj
> I obtains this error:
> Warning 1: PROJ: proj_create_from_database: C:\OSGeo4W\share\proj\proj.db
> contains DATABASE.LAYOUT.VERSION.MINOR = 1 whereas a number >= 3 is
> expected. It comes from another PROJ installation.
> Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF
> keys is not the same as the one from the EPSG registry, which may cause
> issues during reprojection operations. Set GTIFF_SRS_SOURCE configuration
> option to EPSG to use official parameters (overriding the ones from
> GeoTIFF keys), or to GEOKEYS to use custom values from GeoTIFF keys and
> drop the EPSG code.
> ERROR 1: PROJ: proj_create_from_database: C:\OSGeo4W\share\proj\proj.db
> ERROR 6: Cannot find coordinate operations from
> ENGCRS["unnamed",EDATUM["Unknown engineering
> datum"],CS[Cartesian,2],AXIS["(E)",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["(N)",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
> to +proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1
> +units=m +nadgrids=@null +wktext +no_defs +type=crs'
> Please can somebody help me?
> Thank you
> Regards.
> After further investigation I noticed that the problem only exists in the
> first installation (folder c.\OSGeo4W doesn't exist).
> If you update a previous installation everything works.
New description:
Hello,
days ago.
https://download.osgeo.org/osgeo4w/v2 -C Commandline_Utilities -x shell -P
Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF keys
is not the same as the one from the EPSG registry, which may cause issues
during reprojection operations. Set GTIFF_SRS_SOURCE configuration option
to EPSG to use official parameters (overriding the ones from GeoTIFF
keys), or to GEOKEYS to use custom values from GeoTIFF keys and drop the
EPSG code.
I noticed that the problem only exists in the first installation (folder
Thank you
Regards.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/830#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
