[osgeo4w-dev] [osgeo4w] #831: gdal-dev-tiledb package is not up-to-date and gives errors
trac_osgeo4w at osgeo.org
Wed May 1 07:56:03 PDT 2024
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
The latest available gdal-dev-tiledb package is gdal-dev-
tiledb-3.10.0-533-a8af5892ba-1, while the gdal-dev and the other gdal-
dev-* packages are at gdal-dev*-3.10.0-538-5dfa73a9c8-1.
If the latest available gdal-dev (3.10.0-538-5dfa73a9c8-1) and gdal-dev-
tiledb (3.10.0-533-a8af5892ba-1) and tiledb (2.8.2-4) packages are
installed, then the following error is displayed using gdalinfo in the
OSGeo4W Shell on Windows 10 Home 64-bit:
C:\OSGeo4W_V2_8>gdalinfo --version
ERROR 1: Can't load requested DLL: C:\OSF9FA~1\apps\gdal-
dev\lib\gdalplugins\gdal_TileDB.dll
127: Impossibile trovare la procedura specificata.
GDAL 3.10.0dev-5dfa73a9c8, released 2024/04/27
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/831>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
