[osgeo4w-dev] [osgeo4w] #858: poppler depends on openjpeg and curl but they are not among the required packages (was: poppler depends on openjp2 and libcurl but they are not among the required packages)
OSGeo4W trac_osgeo4w at osgeo.org
Wed Nov 13 05:39:37 PST 2024
packages
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Changes (by andreaerdna):
 * summary:
     required packages
     required packages
Old description:
> poppler-24.04.0-2 depends on openjp2 and libcurl libs but they are not
> listed among the required packages.
> To replicate the issue:
> - execute osgeo4w-setup.exe with a clean directory as a target
> - select the packages poppler and poppler-tools to be installed
> see that various needed packages are automatically installed additionally
> to poppler and poppler-tools, but openjp2 and libcurl are not
> automatically installed altought poppler.dll depends also on openjp2.dll
> and libcurl.dll.
New description:
 poppler.dll from poppler-24.04.0-2 depends on openjp2.dll and libcurl.dll
 libs but the openjpeg and curl packages are not listed among the required
 packages.
 to poppler and poppler-tools, but openjpeg and curl packages are not
 and libcurl.dll.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/858#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
