[osgeo4w-dev] [osgeo4w] #878: HAS_KDE_QT5_PDF_TRANSFORM_FIX, HAS_KDE_QT5_SMALL_CAPS_FIX and HAS_KDE_QT5_FONT_STRETCH_FIX CMAKE flags
OSGeo4W trac_osgeo4w at osgeo.org
Tue Apr 15 13:38:14 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  enhancement  |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Old description:
> If the OSGeo4W 's Qt5 builds are built from the KDE's maintained 5.15
> fork containing the "PDF brush transform", the
> "QFont::SmallCaps" the "QFont stretch" fixes, then could the
> https://github.com/qgis/QGIS/blob/db3ed8627a05c5c69c55625c18a57e49db17072e/CMakeLists.txt#L558-L560
> be set for the OSGeo4W's QGIS builds in order to enable the
> features introduced with https://github.com/qgis/QGIS/pull/45946,
> https://github.com/qgis/QGIS/pull/45887 and
> https://github.com/qgis/QGIS/pull/45827?
New description:
 If the OSGeo4W's Qt5 builds are built from the KDE's maintained 5.15 fork
Comment (by jef):
 yes. ;)
 If the fixes are https://invent.kde.org/qt/qt/qtbase/-/merge_requests/57,
 https://invent.kde.org/qt/qt/qtbase/-/merge_requests/58,
 https://invent.kde.org/qt/qt/qtbase/-/merge_requests/59 they should be in
 5.15.13.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/878#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
