[osgeo4w-dev] Offline installer from cache not working
Jürgen E. Fischer
jef at norbit.de
Mon May 18 04:58:42 PDT 2026
Hi Marwan,
On Mon, 18. May 2026 at 11:51:36 +0000, BADAWI Marwan wrote:
> Ideally, if there is a way to install only QGIS and GDAL, that would be
> great, but qgis-full is definitely an acceptable solution.
qgis-full is what gets installed when you pick QGIS in the express install GDAL
is a dependency of QGIS anyway. So that should match your original package
set.
You could install qgis to get only the required dependencies (or qgis-free-full
to just leave out the proprietary ones).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20260518/be17ea8a/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20260518/be17ea8a/attachment.ksh>
More information about the osgeo4w-dev
