[osgeo4w-dev] Offline installer from cache not working
BADAWI Marwan
marwan.badawi at scalian.com
Mon May 18 06:17:39 PDT 2026
Hmmm, qgis-full is installing GRASS for me which we don't need.
When I run the installer in "Express Install" mode, there are 4 choices given: QGIS, QGIS LTR, GDAL and GRASS GIS. I select QGIS and GDAL which are all we need. When I use the qgis-full package with your command line, it seems to me it also installs GRASS as there is a start menu shortcut called GRASS GIS which isn't there when I manually install from the UI.
But like I said, it's OK, I won't waste much time on this (neither yours nor mine 😊 )
Thanks again for all your help!
Marwan
-----Original Message-----
Sent: 18 May 2026 13:59
To: BADAWI Marwan <marwan.badawi at scalian.com>
Cc: osgeo4w-dev at lists.osgeo.org
Subject: Re: [osgeo4w-dev] Offline installer from cache not working
Hi Marwan,
On Mon, 18. May 2026 at 11:51:36 +0000, BADAWI Marwan wrote:
> Ideally, if there is a way to install only QGIS and GDAL, that would
> be great, but qgis-full is definitely an acceptable solution.
qgis-full is what gets installed when you pick QGIS in the express install GDAL is a dependency of QGIS anyway. So that should match your original package set.
You could install qgis to get only the required dependencies (or qgis-free-full to just leave out the proprietary ones).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de/
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
More information about the osgeo4w-dev
