[Osgeo4w-trac] [osgeo4w] #43: change default setup cache dir to
%OSGEO4W_ROOT%\var\cache\setup\
trac_osgeo4w at osgeo.org
Fri Jan 30 13:53:26 EST 2009
#43: change default setup cache dir to %OSGEO4W_ROOT%\var\cache\setup\
Reporter: maphew | Owner: osgeo4w-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Installer | Version:
Keywords: setup, apt |
Please consider changing the default cache for osgeo4w-setup.exe to
%OSGEO4W_ROOT%\var\cache\setup\. This would enable wiki:pkg-apt to share
the cache with a minimum of fuss.
The install root is set in step #3 "OSGeo4W Setup - Choose Installation
Directory", while cache is set in step #4 ""OSGeo4W Setup - Select Local
Package Directory". So I think it should be possible.
Con:
- Slightly more difficult to erase o4w and start over. With the default
package directory in the same folder as osgeo-setup.exe one can simply
delete %OSGEO4W_ROOT% and run setup again without forcing a new download.
If the packages are under %OSGEO4W_ROOT%\var deletion needs to be more
selective. In my opinion the tradeoff is worth it. We can write a "delete
all but download cache" script if need be.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/43>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
