[Osgeo4w-trac] [osgeo4w] #44: Gdal/Proj problems with Grass installation
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jan 30 14:23:29 EST 2009
 Reporter:  cnielsen   |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:
Component:  Installer  |     Version:
 Keywords:  grass      |
 Several errors come up when starting grass, and it seems they relate to
 gdal and proj.
 Starting grass in text mode, g.region -p gives error:
  "This application has failed to start because gdal16.dll was not found.
  Re-installing the application may fix this problem"
 The same error occurs with the test version 6.4.0RC3.
 For related errors in tcltk mode see: http://lists.osgeo.org/pipermail/
 grass-windows/2009-January/001658.html
 The file gdal16.dll is not located anywhere within the OSGeo4W directory.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/44>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
