[Osgeo4w-trac] [osgeo4w] #95: python programs that uses grass.py do
not work with --interface-description, --help, or --ui
trac_osgeo4w at osgeo.org
Tue Jul 7 02:19:57 EDT 2009
#95: python programs that uses grass.py do not work with --interface-
Reporter: cgsbob | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
I've developed a python script that uses the GRASS python module grass.py.
When I use the options --help (displays command help), --ui (starts up a
gui form for my command), or --interface-description (xml description of
the gui), I do not see any output. Without --interface-description, I am
not able to use my script in QGIS Toolbox.
Based on a discussion on the GRASS user ML (see [http://n2.nabble.com/
Problems-with-GRASS-python-code-in-osgeo4w-td3122413.html]), it appears
that the current version of OSGEO4W needs
[http://trac.osgeo.org/grass/changeset/37075] and there seems to be
problems on how paths are specified in batch files.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/95>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
