[Osgeo4w-trac] [osgeo4w] #96: "import grass.script as grass" in
 Python GRASS AddOns doesn't work
    trac_osgeo4w at osgeo.org
    Tue Jul  7 08:00:36 EDT 2009
#96: "import grass.script as grass" in Python GRASS AddOns doesn't work
Reporter:  aghisla  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect   |      Status:  new
Priority:  major    |   Component:  Package
 Version:           |    Keywords:  grass addon python grass.script
 I'm trying to run a Python AddOn in OSGeo4W GRASS. There are some problems
 in getting grass-python module work.
  1. Native install: [[BR]]
  * GRASS 6.4.0svn2 [[BR]]
  * bundled Python
 Welcome to GRASS 6.4.0svn (2009)
 Microsoft Windows XP [Versione 5.1.2600]
 (C) Copyright 1985-2001 Microsoft Corp.
 GRASS 6.4.0svn (spearfish60)> python C:\v.krige\v.krige.py
   File "C:\v.krige\v.krige.py", line 54, in <module>
 ImportError: No module named script
  2. Modified install: [[BR]]
  * as above [[BR]]
  * python folder in C:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\ substituted
 with the python folder in grass6_develbranch, rev 38064
 ImportError: No module named grass.script
 Python 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit
 (Intel)] on
 win32
 >>> import core as grass
 >>> grass.run_command("g.list", type="vect")
 vector files available in mapset <PERMANENT>:
 archsites       roads           t_9961_200      t_9961_500
 t_roads_prime
 so bundled Python can actually import the module, but not as grass.script.
 There's something I'm missing, but hope this report helps.
 BTW, there is a similar ticket (#95) but about QGIS and not on the same
 issue, but also about grass module.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/96>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
