[Osgeo4w-trac] Re: [osgeo4w] #73: grass64 file has non-general file
path
trac_osgeo4w at osgeo.org
Mon Mar 30 09:54:49 EDT 2009
#73: grass64 file has non-general file path
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: grass |
Comment (by cnielsen):
As the terminal seems to be unavailable when starting with the grass.bat
icon, personally I would like that file to be left in place. As far as I
have found, the only way to keep a functional terminal is to open msys and
start grass using this grass64 file (after adding /osgeo4w/apps/grass/bin
to PATH in /etc/ini/grass.bat) see
<http://trac.osgeo.org/grass/ticket/533>
Also when using msys for other functions (compiling, etc.) it is nice to
be able to still start grass from the command line. Is there some way to
make both of these function?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/73#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
