[Osgeo4w-trac] Re: [osgeo4w] #73: grass64 file has non-general file path
OSGeo4W trac_osgeo4w at osgeo.org
Mon Mar 30 10:35:03 EDT 2009
Reporter:  cnielsen  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  new
Priority:  major     |    Component:  Package
 Version:            |   Resolution:
Keywords:  grass     |
Comment (by jef):
 Replying to [comment:2 cnielsen]:
 > As the terminal seems to be unavailable when starting with the grass.bat
 icon, personally I would like that file to be left in place.
 hm, on Windows {{{grass64.bat}}} and not the {{{grass64}}} seems to be the
 intended way to start GRASS.  Therefore {{{grass64.bat}}} was customized
 and copied to /bin for OSGeo4W.
 It starts {{{apps/grass/grass-6.4.0svn/etc/Init.bat}}} which in turn
 starts the text or GUI interface and doesn't leave a command prompt open
 in the latter case.
 So if the current behaviour is not intended {{{Init.bat}}} is the place to
 change that.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/73#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
