[Osgeo4w-trac] Re: [osgeo4w] #151: installation from local package
 don't check the dependencies
    trac_osgeo4w at osgeo.org
    Tue Feb 23 10:35:54 EST 2010
#151: installation from local package don't check the dependencies
Reporter:  yjacolin  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect    |       Status:  new
Priority:  major     |    Component:  Installer
 Version:            |   Resolution:
Keywords:            |
Comment (by warmerdam):
 I don't understand what mode is being used instead of internet mode.  Have
 you already downloaded all packages and the setup.ini to a local cache
 directory and are operating against that?  Is this a "first run" of
 osgeo4w setup on the system or is there an existing installed tree?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/151#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
