[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
trac_osgeo4w at osgeo.org
Thu Mar 18 08:34:24 EDT 2010
Reporter: lutra | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal, gdal utilities |
Comment (by jef):
Replying to [comment:21 brushtyler]:
> About gdal in qgis, in linux gdal1.6 *overwrite* gdal1.5, then why the
osgeo4w on win doesn't have the same behaviour? [[BR]] If I install gdal16
lib, I suppose and want (if supported) it will be used!
You can have both GDALs. In OSGeo4W and under Linux. Which one is used
is controlled by environment variables (PATH on Windows, LD_LIBRARY_PATH
on Linux).
{{{gdal16.bat}}} sets up the environment so that the GDAL 1.6 binaries and
libraries are used and also sets {{{PYTHONPATH}}} so that the right GDAL
bindings are found.
> I think this is an osgeo4w issue, do you?
Probably. But if that is only happening on Windows 7/Vista, we must be
missing something special there, but generally it should work - and
unfortunately also works here with Win7 64Bit.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:22>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
