[Osgeo4w-trac] Re: [osgeo4w] #161: gdal utilities issues
trac_osgeo4w at osgeo.org
Thu Mar 18 09:02:11 EDT 2010
Reporter: lutra | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal, gdal utilities |
Comment (by lutra):
> Probably. But if that is only happening on Windows 7/Vista, we must be
missing something special there, but generally it should work - and
unfortunately also works here with Win7 64Bit.
Hi Jurgen,
until now I haven't find a single Vista/Seven machine where the osgeo4w
gdal .exe utilities do work without crashing. In all the pc where I
installed osgeo4w were typical user machines, nothing special installed
related to development & co. This should be have some meaning... that -I
guess- in general the osgeo4w gdal utilities doesn't work (under
Vista/Seven).
It should be easy during the hackfest make the necessary comparison from
your machine and another Vista/Seven installation. I'll miss the hackfest
but I'm sure Giuseppe can have a look to it with you.
Cheers
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:23>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
