[Osgeo4w-trac] Re: [osgeo4w] #286: The procedure entry point not
found sqlite3..
trac_osgeo4w at osgeo.org
Thu May 10 16:05:48 EDT 2012
#286: The procedure entry point not found sqlite3..
Reporter: mgala | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Keywords: QGIS
Comment(by warmerdam):
It at least one roughly similar case the problem was an older sqlite3.dll
living in the windows system directory. The user had to replace it
manually with our sqlite3.dll from C:\OSGeo4W\bin. This affected QGIS,
but not (for instance) gdalinfo since QGIS does not run from he
C:\OSGeo4W\bin directory.
One potential solution would be to repackage a custom sqlite3 dll with a
different name. This strategy has been used for a few other common low
level libraries. But it would be a substantial effort to get right and
make future upgrades hard (because we couldn't use binaries provided by
the sqlite project).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/286#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
