[Osgeo4w-trac] [osgeo4w] #290: Missing files
OSGeo4W trac_osgeo4w at osgeo.org
Sat May 12 21:41:59 EDT 2012
#290: Missing files
Reporter:  edi151  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  missing files
 Please see attached prt scrns showing why OSGeo4W won't load.
 [[Image()]]Not clear to me how to attach anything yet box below indicates
 you can attach things?
 '''2 problems''':
 1. Command line Error message says it can't load
 DLL:C:\OSGeo4W\bin\gdalplugins\gdal_SDE.dll because it couldn't be found
 2. When I try to set GDAL/Configuration in IDRISI GDAL Module it says no
 "gdal_17.dll file". Have downloaded and installed twice and same result.
 Windows Explorer search confirms there is no gdal_17.dll file.
 Your help and advice on how to correct these 2 problems would be much
 appreciated.
 Sincerely,
 edi151
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/290>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
