[Osgeo4w-trac] Re: [osgeo4w] #290: Missing files
    trac_osgeo4w at osgeo.org
    Mon May 14 12:46:45 EDT 2012
#290: Missing files
Reporter:  edi151  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  missing files
Comment(by maphew):
 The last line indicates gdal 1.7.3 is installed, yet current is 1.9.0. Is
 this a fresh install?
 Unless you need v1.7 specifically perhaps try uninstalling the `gdal17`
 package and install `gdal` instead (which will always grab the current
 version).
 You may also need to remove: `gdal17-ecw, gdal17-mrsid, gdal17-python`
 The Arc SDE plugins are `gdal-sde90, gdal-sde91, gdal-sde92`, correspond
 to Arcgis SDE versions 9.0, 9.1 & 9,2 respectively. They require files
 which need to be acquired from Esri (but not the one listed in the error
 message). Uninstall these too unless you know you need them.
 The missing `o-help-list.txt` file raises a question mark for me but is
 not related (it's the file from which the "-={ OSGeo4W Shell Commands }=-"
 message is generated, so clearly it's present at some point).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/290#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
