[Osgeo4w-trac] [osgeo4w] #314: Minor typo in Initialising BAT file
    trac_osgeo4w at osgeo.org
    Wed Oct 31 06:28:18 PDT 2012
Reporter:  aharfoot  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  trivial   |   Component:  Package
 Version:  1.0       |    Keywords:  bat
 The OSGeo4W init BAT file (%OSGEO4W_ROOT%\etc\ini\python.bat) has a typo
 on the last line:
 set _path
 Should be modified to be:
 set _path=
 This will clear the contents of the temporary '_path' environment variable
 (as in OSGeo4W.bat), instead of the current behaviour which is to display
 the value.
 Environment:
 OSGeo4W shell: 1.0.0.10
 OS: Windows 7 64 bit
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/314>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
