[Osgeo4w-trac] [osgeo4w] #315: Spaces in install path breaks OSGeo4W.bat
OSGeo4W trac_osgeo4w at osgeo.org
Wed Oct 31 06:43:27 PDT 2012
Reporter:  aharfoot  |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  major     |   Component:  Package
 Version:  1.0       |    Keywords:  batch file
 If the OSGeo4W.bat command shell initialising script is run from a
 location with spaces in the directory path, then it will fail. This issue
 is commonly encountered when using the standalone QGIS installer (1.8.0.1)
 as the default Windows install path is C:\Program Files\Quantum GIS...
 The following QGIS bug report gives modifications to two of the batch
 files called in the initialisation sequence (osgeo4w.bat and o-help.bat)
 that appear to solve the problem.
 http://hub.qgis.org/issues/5345
 OSGeo4W command shell package: 1.0.0.10
 OS: Windows 7 64 bit
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/315>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
