[Osgeo4w-trac] [osgeo4w] #340: OSGeo4W not accessing ESRI filegdb
trac_osgeo4w at osgeo.org
Thu Apr 25 15:14:49 PDT 2013
Reporter: wyogeo | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: worksforme
Keywords: ogr, filegdb |
Changes (by saultdon):
* status: new => closed
* resolution: => worksforme
Comment:
You shouldn't actually need to download the filegdb api and place dlls
anywhere anymore.
All the needed files to read/write file geodatabases are available through
the package '''gdal-filegdb''' found in the ''libs'' category.
I've installed gdal and gdal-filegdb using the osgeo4w installer and can
access that test_fgdb.gdb fine.
Feel free to re-open if this doesn't solve your problem, as something else
could be wrong and more troubleshooting is needed =)
== NOTE ==
If you do choose to manually place the ESRI FileGDB dlls into the bin
folder, make sure you try with the 2008 and 2010 builds because one may
work and they other may not. Also, it may matter to grab the 32-bit dlls,
because GDAL from the osgeo4w installer is a 32-bit version I think.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/340#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
