[Osgeo4w-trac] [osgeo4w] #340: OSGeo4W not accessing ESRI	filegdb
    trac_osgeo4w at osgeo.org
    Thu Apr 25 16:32:17 PDT 2013
Reporter:  wyogeo        |        Owner:  osgeo4w-dev@…
    Type:  defect        |       Status:  closed
Priority:  major         |    Component:  Package
 Version:                |   Resolution:  worksforme
Keywords:  ogr, filegdb  |
Comment(by jef):
 Replying to [comment:1 saultdon]:
 > If you do choose to manually place the ESRI FileGDB dlls into the bin
 folder, make sure you try with the 2008 and 2010 builds because one may
 work and they other may not. Also, it may matter to grab the 32-bit dlls,
 because GDAL from the osgeo4w installer is a 32-bit version I think.
 See [[wiki:pkg-gdal-filegdb]]
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/340#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
