[Osgeo4w-trac] [osgeo4w] #27: Package gdaI-dev: ippj-5.3.dll not found
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 12 12:27:20 PDT 2014
Reporter:  klokan  |        Owner:  warmerdam
    Type:  defect  |       Status:  reopened
Priority:  major   |    Component:  Installer
 Version:          |   Resolution:
Keywords:  ipp     |
Changes (by jvdmdoacpro):
  * status:  closed => reopened
  * resolution:  wontfix =>
  * component:  Documentation => Installer
Comment:
 Replying to [comment:8 warmerdam]:
 > gdal-dev package removed, ticket no longer relavent.
 Dell Inspiron 5110N with Intel i7-2630QM (2.0 GHz) Widows 7
 Using "osgeo4w-setup-x86.exe" to install from internet (Grass 6.4.3)
 Installed "Advanced Install" with only non-web based installation - Have
 problem with running at */etc/postinstall/qgis-common.bat - some python
 problem.
 Uninstalled everything
 Installed "Advanced Install" with ALL options - Have problem with some
 sub-programme complaining about ippj-5.3.dll already during install as
 well as when invoking qgis.bat
 This ticket is OLD, but apparently became alive again!.
 Now how is it possible that something that has been removed, remain
 causing problems?
 It is either there or not - cannot be both.
 I had a perfectly good 6.4.0 working - after "upgrading" to 6.4.3 all hell
 broke loose.  None of the suggestions on any of the forums is resolving
 anything.  Only managed to get latest SAGA going through its own
 installer.
 Reinstallation reports on postinstall (umpteenth time)
    Package: ka-map
            ka-map.bat exit code 1
    Package: qgis-common
            qgis-common.bat exit code -1073741515
    Package: qgis-dev
            qgis-dev.bat exit code -1073741515
 Should I scrap the entire computer for a new one perhaps?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/27#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
