[Osgeo4w-trac] [osgeo4w] #27: Package gdaI-dev: ippj-5.3.dll not found
trac_osgeo4w at osgeo.org
Wed Mar 12 13:08:09 PDT 2014
Reporter: klokan | Owner: warmerdam
Type: defect | Status: closed
Priority: major | Component: Installer
Version: | Resolution: fixed
Keywords: ipp |
Changes (by jef):
* status: reopened => closed
* resolution: => fixed
Comment:
Replying to [comment:9 jvdmdoacpro]:
> Installed "Advanced Install" with ALL options - Have problem with some
sub-programme complaining about ippj-5.3.dll already during install as
well as when invoking qgis.bat
Calm down please. Why did you install ALL packages? No need.
Anyway, that means you installed voluntarily installed libjpeg-ipp
although nothing depends on it anymore (gdal-dev appearenty used to).
But you missed to install the third party stuff that it depends on and
therefore everything depending on libjpeg went defunct (see [wiki:pkg-
libjpeg-ipp]). Either install the missing dependencies or remove libjpeg-
ipp and reinstall libjpeg-6b.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/27#comment:10>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
