[Osgeo4w-trac] [osgeo4w] #415: Don't assign .qgs extension to qgis-dev.bat
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 22 09:34:57 PDT 2014
Reporter:  AndreJoost   |        Owner:  osgeo4w-dev@…
    Type:  enhancement  |       Status:  closed
Priority:  major        |    Component:  Installer
 Version:               |   Resolution:  fixed
Keywords:               |
Comment(by jef):
 Replying to [comment:6 AndreJoost]:
 > Replying to [comment:5 jef]:
 > > You can just doubleclick the {{{apps/qgis(-dev)/bin/qgis.reg}}} in
 either install to switch the registration.
 > OK, that worked. Is this documented somewhere in a userfriendly way?
 No, it's create in the installation process and was never meant to be
 executed manually.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/415#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
